gasket off exhaust mani and crankcase removed with razor and then scotch brighted smoothed.
http://farm7.static.flickr.com/6201/...e25414e3_z.jpg
DSC04982 by docdrs, on Flickr
new crankcase gasket
http://farm7.static.flickr.com/6075/...9f4d01fc_z.jpg
DSC04983 by docdrs, on Flickr
which ring goes on top? silver or black
http://farm7.static.flickr.com/6189/...ffd64441_z.jpg
Untitled by docdrs, on Flickr
the silver one goes on top
now how am i going to get the jugs over the pistons while compressing the rings with no room to work????
http://farm7.static.flickr.com/6198/...22e67086_z.jpg
http://farm7.static.flickr.com/6181/...041cd287_z.jpg
Would love to know what this would have cost you if you had dropped it off at the shop compared to your monetary and time investment.
so I used 2- 3.5 inch clamps on the pistons to compress the rings and with my bro inlaw we slip the jugs down over the pistons one at a time in about 10 minutes .....Voila..... happy camper......but wait tightened and torqued jug to crankcase.....then placed exhaust mani gasket and tightened exhaust mani to jugs and some of the bolts did not seem right.......one was down right not going in ......so executive decision remove jugs and find out what the issue is.....turns out shop blasted top and holes and shit was left in threads I think.......so back to have them tapped and get me a new bolt that stripped.....thank god it was one I could get totally out of the exhast mani.......a wee bit pissed so I had another beer and called time out.......btw the clamps worked well and I decided to change my oil filter and had to remove the entire exhaust pipe with silver manifold attached , the big black pipe to the orange rubber hose joiner hidden behind jugs, to get to it, it was just the rubber boot and a cooling hose hidden on the underside at the front .......wow what a pita for a filter.......way easier to work on the indmar motors
jugs on Happy camper but wait things went too easy>>>>>>>>
http://farm7.static.flickr.com/6189/...bb0f331c_z.jpgDSC04987 by docdrs, on Flickr
stripped bolt , back to the machine shop..... arrrrgh notice jugs out and back on floor .... wine time :)
http://farm7.static.flickr.com/6200/...239e5815_z.jpg
DSC04989 by docdrs, on Flickr
Thats more like it... lol, kinda the way things go for me, nothing is ever straight forward, or works out the first time.
So , I could not leave it till tuesday , my tap and die set up north....so I bought another at my favorite rental place Canadian tire...... Tapped out all holes on the jugs, there was sand blast crap in the holes. I could not get a bolt to match the one that stripped so I re die'd it and wham , I'm back in business.
first, left mag cylinder in sleeve....note clamp on right one holding rings in place.....now as my trusty assistant holds the jugs steady, I pull the right one up into the cylinder until I feel the clamp slide down the piston and the piston slide up into the last cylinder. Remove the 2- 3.5 in hose clamps and seat the jugs down onto the crankcase and gasket
http://farm7.static.flickr.com/6190/...b9571aec_z.jpg
DSC04992 by docdrs, on Flickr
note clamp
http://farm7.static.flickr.com/6206/...40bd379d_z.jpg
DSC04991 by docdrs, on Flickr
Jugs back in place and rest assembled. All bolts torqued in pattern and to specs. I also replaced my fuel filter ( tough to get those oem clamps off, replaced with hose clamps) and did a pressure test as it went from 80 psi to 120 psi ...a possble culprit for lean condition.
http://farm7.static.flickr.com/6209/...e2dceb45_z.jpg
DSC04993 by docdrs, on Flickr
also did a compression test 125 on both cylinders, pretty good considering nothing is worked in yet
http://farm7.static.flickr.com/6196/...2aee62ea_z.jpg
DSC04995 by docdrs, on Flickr
And lastly of course it started raining , so a quick pull out of the garage and she fired up right away :)
Update. Ran my seadoo for about 2 hours this weekend. Smooth and 60 mph top end. I then pulled both plugs to find them both tan in colour , the way they should be. Rebuild appears to be a success. :)
http://farm7.static.flickr.com/6191/...0a73e5f1_z.jpg
DSC04999 by docdrs, on Flickr
Congrats and thanks for sharing this. Way cool thread and well documented as usual.
