Has anybody got the underwater LED's as an option from the factory? Do you get your choice of color or is it a standard color? Pictures are appreciated.
Low lights would be nice to see as well.
Thanks in advance
Thanks in advance
They are blue.
2016 factory underwaters ....
In Arkansas water ;)
https://uploads.tapatalk-cdn.com/201...20cecfefe5.jpg
https://uploads.tapatalk-cdn.com/201...9f530b1dba.jpg
Show it to them in murkey water
Nope, can't do it.
Yeah, we need to see it in the murk like Trinity.
I was looking at my 2017 Craz the other day, and it appears that all the new boats must be pre-wired from the factory for underwater lights. One of the accessory switches on the dash has a blue wire with a green stripe, I traced this wire all the way back to the transom (tucked in up and to the right -way up) and there is a butt connector there, along with a black negative also with a butt connector. So you can hook up one of those drain plug LED lights. I have one on order, so it should be simple to install and crimp to the existing butt connectors.
PS there is also a breaker under the dash for underwater lights that is 3A
Yes, i think they have been prewired for several years now.
Is the wakeplate not going to be in the way of the drain plug light?
Good thing you asked. The first one I bought had a massive head on it, and I could not screw it in, because it interfered with the wake plate. So I have ordered another one that is a smaller diameter similar to the size of the factory drain plug. So if you're going to order one that's what you want to look for. I can send you a link if you would like to show you the one I got
