Bigger gas tank & new carpet?
I have a couple of sort of odd questions. First, is there any way to put a larger gas tank in my 2001 Outback DD? With only a 27 gallon tank and about 1300 pounds of ballast, I only get 6.5 hours at the absolute maximum on the lake. Now considering that in the middle of summer there are 14+ hours of daylight, this can be annoying. I have to either get to the lake late or leave early all while keeping my eye on the hour meter (since the fuel guage is useless). If I take out the factory ballast tanks, there is physically room, but is it worth the hassle to find a larger tank (which one would fit or, worst case, would I have to get one made) and deal with switching it out?
Second, my carpet could use replacing, and I don't want to deal with cutting the new carpet around everything, and I want a properly done job. So is it possible to separate the top and bottom hull pieces without too much work? Are they just screwed together or is there some NASA developed super epoxy in the joint as well. It would be nice to be able to do this, then the new carpet can be laid down in large pieces and it would go under everything, just like it is from the factory.
So are these possible or do I just need to buy a few 5 gallon gans cans and deal with some carpet that is not perfect? Or maybe I should just buy a new Mobius LSV. It has both a 40 gallon tank and new carpet! Although 40 gallons is still only abuot 8-10 hours of fuel.
