I have a '13 LSV with an IBS and the center tank is leaking. Has anyone replaced the tank with bags? Maybe cut the end of the center ballast tank and slide a bag in the opening? Any ideas?
Mine is leaking in my 14' lsv. Just running the ibs separately for this year till I figure out what I wanna do with the cracked tank. Don't think you can slide a bag in because of the center supports built into the tank. But that would be a great idea...
Jordan
2014 moomba möbius lsv
How do you bypass the center tank?
I ran a new hose from outlet on the pump for the center tank to the ibs. Left the hose from the center tank sit unhooked. I think once I fix my center tank I wanna run my ibs seperately to be safe anyways.
Jordan
There's a guy on here that replaced his center tank and had a pic of it. It was solid and there were no supports in the tank. I seriously thinking about the bag. Thanks for the help with the ibs. Haven't thought about running a hose.
I am the guy that replaced my tank. You will have to remove your fuel tank to get the tank partially out. You will have to either cut it up or pull the v-drive to get it all the way out. The tank itself has center supports, so you cannot slide a bag into the tank. Remove the tank and there is plenty of room for a bag if you wish.
Fuel tank is out. Ballast tank is out also. Searching for a bag to replace it
And did you have to do like jstenger and cut the fibreglass and remove v drive?
Jordan
Had to cut the lip so that the tank would slide out. I wasn't happy with the design of the tank so I decided to cut the end off and slide it out without having to remove the V-drive. I checked the tank but wasn't able to find where it was leaking. Just ordered a bag from Wakemakers that will fit.
