I have a 2014 Moomba with the 330 HP engine.
Is this the O2 sensor I need:
https://www.bakesonline.com/indmar-e...manifolds.html
Thanks in advance and yes I was getting an O2 sensor at the end of last year so time to rectify that.
I have same year and same mode boat with 345 engine and have been getting O2 sensor error popping up a few times a season. What error are you getting? I’m getting SPN3050 FMI 11 . I may replace it this year in the off season. Following this thread as I may need the same thing…
I think that is the one I was getting. One of the numbers indicates right or left. I switched the sensors and the code popped for the other side so I'm pretty sure mine is bad. I'll check on the code from the boat in the next day or 2.
Keep me posted how it goes, and what part you end up with - I’ll likely need to do the same when my boat comes out of winter storage - good luck!!
Finally ordered the part, I'll let you know if it works.
Installed a couple of weeks ago and no issues.
