Do it. Wish I would have years ago!
https://forum.moomba.com/showthread....371#post221371
Yep, the lockers are an inch lower than the under seat storage area so it makes the transition easy. Good luck - I think you will be happy.
I just pulled the carpet today, left the 3 or so inches after the wall until I get a chance to pull all of that as I ran out of time. Haven't decided if I am going that hydro turf route or the stuff from lowes/HD. The glue was a bit of a pain but not bad. Or maybe spray the truck bed liner in there or just do that on the walls? Not sure just yet but thankfully that nasty carpet is out.
BR what was the prep you had to do for the Herculiner? You rolled it? Would spray work?
I cleaned the glue off with acetone and a razor scraper, and scuffed it up a bit before rolling it on. Yes, I think spraying would work fine too if you did more masking.
