Engine overheated 2014 moomba mondo
Ok so yesterday we were headed back toward the launch ramp doing about 35-40 mph and all of a sudden a mixture of blue smoke and steam was coming out from the back of the boat. I stopped immediately and shut the motor down. Temperature was showing around 220 degrees. When I opened the engine compartment I notice the outlet hose coming off the raw water pump was off and pumping water into the bildge. I did not start it back up and got a tow back to the ramp. After we got home I inspected the raw water pump and impeller everything was intact. I checked all fluids, everything looked good nothing smelled burnt or looked milky. I hooked the hose back up and started the motor on the fake lake. Water circulates through the motor and out the exhaust. However the port side exhaust had less water coming out. Also the 3/4" thread to 1" barb nipple on top of the starboard exhaust riser was leaking water. Needs to be replaced. Can anyone tell me what happened and what further damage I need to look for?
