https://uploads.tapatalk-cdn.com/201...31f4fad5e1.jpg
After looking at the pic looks like your testing it via wifi. Make sure you reboot the uverse router setup, then test while close the to router. If you have an Xbox, you should try plugging it into the uverse box and running the same speed test. You want to find out what the max speed you have available from the Uverse side. You'll also want to run the wifi test around your house, see if it's better or worse in other locations. You may just need to move the devices around. :) If you need better coverage you can look at the google mesh, or a newer wifi router link I provided.
