Bag fill timing question( I am overfilling)
2018 SA, factory ballast.
Fill time settings:
7:30 fill time for rears and 9:00 center
I started noticing I start spilling water out of ballast vents earlier and earlier.
My assumption is my drain time needs to be increased and each time I drain, I am leaving more and more water in the ballast tanks, therefore my fill times are off more each time.
Even with the bag overflows running, I pushed one of the rear engine dividers out of place. It popped right back in, but it tells me I am way overfilling the bags.
I pulled boat out of water and noticed I could drain an additional 60 seconds worth of water before the pumps started spitting air.
Is adding an additional 60 seconds on the drain timer the right approach?
