Originally Posted by
RC_Hinojosa
I have a Craz with the upgraded prop and I generally run 4,600lbs with a small crew....4-5 peeps.
Enzo rears (1450s)x 2 + belly tank (700lbs) + IBS (500lbs) + 500 lbs of lead
I stash my lead under the bow cushion and you can't even see it.
AutoWake by design would empty the Enzos to lower the pitch so the extra bow weight helps prevent that from happening.
In the event that there are only 3 of us, I also have a 1000lb Sumo Sac that fits perfect in the spot over the Vdrive hump when the rear seat is slid forward.
If you run upgraded rear bags you will definitely want to reinforce the engine panels... DIY or Wakemakers has a kit.
