So that looks to be in the factory location. I'm hoping to add some in addition to factory and not sure if the best place to not interfere with the Bimini. Can a board be strapped on top of the factory Bimini like I've seen on a Z5?
I have a spare rack I used on my LSV. It holds 2 surf boards.
I can get you pictures of you like.
I want to say its this exact one.
http://www.bulletlines.com/double-wa...ack-p/1555.htm
What I do with the oz tower is lay the surfer lengthwise on top the tower one on each side and drop the bimini top in the boot on top and strap her down. It works good up to about 40mph. I place some foam pipe insulation on the tower to protect it. It also works as a bimini itself. Be careful with longer boards so that the rope does not catch it when the rider cuts out. I will try to post pictures next time I am on the boat.
I'm interested to see this. I'm really trying to figure out a way to utilize the space on or above the Bimini without dropping $300 for a new rack.
I have rear bags, I run about 1800 in the lsv. Do I need to up the rears to 750s?
Sent from my iPhone
I'll have to double check what we were running. I went out with a buddy who had an lsv and he had a consistent setup. I'll double check with him but what he said was 900 in the rears, belly full with a 225 piggy backed on it
http://img.tapatalk.com/d/14/07/17/eqa5uny7.jpg
