Thanks for your reply, I think I have a vapour lock problem and I am considering installing the 2nd pump. Do you perhaps have the specs for a high volume low pressure pump. This will help me in buying the correct pump.
The ACME site explains how to read your propeller.
http://www.acmemarine.com/our_props.php
The numbers stand for diameter and pitch.
I just called ACME and gave them all of your information. The salesman said you are running a "4th gear prop" and at your altitude you can't get the RPM you want out of it.
He recommends going to the ACME 537 which is a 13.5 x 16 prop. Or, for even more low end pull for wakeboarding but giving up some top speed, you can go to the ACME 1579, which is a 13.5 x 14.25 prop.
I hope this helps you.
Thanks this helps a lot. I have decided to go with the 1579.
Before I can place an order I need to be sure of the shaft size and rotation of my boat.
ACME has suggested that I contact MB and post my Hull ID ( US-ISRML006H405 )
Is there anyway that you can check for me ?
Also ACME does not want to sell directly to me in South Africa and we do not have any dealers here.
Any suggestions???
Here, let me google that for you:
https://www.google.com/shopping/prod...67982277063634
Wakemakers has a good price new or used and ship internationally.
