2019 Makai Surf Setting suggestions
Quote:
Originally Posted by
HFarr
I don't have WM upgrade. I do see FatSac written on one end of them. Not sure if that's who Moomba used that year or not. I didn't order the boat. I got lucky and came along just after someone that did order it had their deal fall through when it came in. My build sheet doesn't indicate anything special about a ballast upgrade.
FatSacs are the OEM 1,000# bags.
dyrmz134
Ah-good info. I have seen the red dot, not sure if they relocated the sensors. Any idea how hard it is to relocate them? Is it just a slide it up thing or a full modification to the tube?
First thing I would do is get in there and remove the rear wall to see if they relocated the sensor or not. If they didn’t it is actually pretty easy just need some parts from Wakemakers. You just add 10”-12” between the tube and the hose that connects to the bag and then zip tie the sensor as high as possible in the corner of the boat. Toughest part is just working in the smaller space.
