My 2013 LSV steering wheel has some play in it, about 1/4 turn turn each way. Is there away to adjust the wheel so it doesn't have the sloppy steering?
Mine is really annoying when not towing but it's barely noticeable when there is a rider back there. Still, if you find a nice solution, please share.
I just purchased a new 2019 Craz. I traded in a 2016 Craz. I am experiencing the same issue on my 2019, and it just started after about 10 hours. I did not have this issue on my 2016. There is a very slight movement in the rudder in the 1/4 turn then it feels like the rudder catches. Since there is a slight rudder turn, the dealer feels this is normal, but it does not feel right to me. If you come up with a solution, please respond. It is hard to believe that there would be a steering cable problem with a new boat with so few hours. Not sure what has happened, but would like to figure it out.
have owned tiges and supras. all did the same thing to varying degrees.
Just got back from the lake. If there is a little bit of play in my steering wheel, it is too small to notice. Certainly not 1/4 turn!. If there is , its barely noticeable. I'd keep searching for an answer. I think that would prolly drive me nuts.
I don’t think a little play in the wheel has anything to do with the cable, I think this is due to a small amount of slop in all the linkages. I have heard doing hydraulic steering eliminates this but I’ve never tested that out.
When first taking off while surfing if the rudder is positioned a certain way I get a really bad shudder in the wheel from the proper wash until I straighten it out.
El cable es una historia diferente.
