2010 Möbius XLV GG with GIII ballad and perfect pass. When I go into the menu setting on the perfect pass I don't see the blst parameter. Do I not have a perfect pass? How can I change my timer? I've got 1100s rear and 1180 in the playpen locker.
Perfect pass and ballast timer are completely separate on that year Moomba.
Timers are probably Jabsco and have to be put into setting mode to adjust. Follow this procedure.
http://www.wakemakers.com/media/wysi...structions.pdf
I did it for my buddy. Basically turn of the power to ballast pumps, then right after you turn it backs on, go through the cycle of turning them on and off, and then they will start flashing and you can adjust the time for each one.
