How are yall putting oil into the vdrive? Through the walter dip stick hole?
yes, get a small funnel
I can say also that I'm pretty sure the specs in the manual are wrong when it comes to the quantity. I think the book calls for 0.5 qts, when mine actually took a full quart. Just be sure you check it.
Unscrew the vent cap and use that hole. Much larger than the dip stick hole. Specs call for 1 qt of 30 WT but that is when completely empty so a little less than that on a normal oil change.
I think mine is starting to leak somewhere. It seems to be lower on the Walter dip stick after each trip. :( Any suggestions? I asked my mechanic he said possibly a loose/cracked hose.
