That's my only complaint. Wish I would have searched around a bit more before putting the factory unit in.
This was one of the cheapest things I've done to the boat yet, and yet one of the things I am most excited about.
I feel like if there is a varying degree of "slop" in the swim platform, mine would have been on the 'worse' end of things. At the very least, its annoying as hell.
Before Video:
http://www.youtube.com/watch?v=X6gXetJpjeI
So, I figured if I could put a few set screws into the bracket, it would at least reduce the rattle a little.
A blank slate:
https://forum.moomba.com/attachment....1&d=1303689419
So, I just drilled and tapped a 3/8-16 hole about mid-way on the inboard side of the platform bracket. I actually bought Stainless Steel allen bolts for this application, but I couldn't find the correct size wrench, so for testing it out I used a few spare Zinc plated bolts I had laying around. I'll swap in the allens once I get the correct wrench:
...and the verdict: NO MORE SLOP! It didn't just reduce the sloppy clunking, it completely eliminated it! I'm so happy, I can't wait to get it in the water and see if its a permanent fix, or if I'll need some more tweaking.
Question: Does anyone know how I can get that oxidization off the platform brackets? I've tried everything, and nothing seems to work...
Ian, I think this is good enough to copy and paste up a HOW TO. Nice work!
So which transducer did you go with to get the water temp, thru hull I'm assuming?
I ordered a Lowrance PDRT-WSU - I believe the depth transducer is a 'shoot thru hull' and the water temp sensor is a drill thru hull. They are slated to arrive this week, so I'll post up my progress on that project when they do :)
Good idea! Done:
https://forum.moomba.com/showthread....767#post134767
Perfect! Thanks!
ideas always show up after I do something. thats it. no more mods for me
I liek the idea Ian, i have the same slop but its pretty small compared to what you had in your video.
Did you take the brackets off to drill and tap?
