Originally Posted by
TXSurf4
Best bet is to call the dealer. When I take mine in to the dealer in November they winterize it, change all the fluids, replace the water pump impeller and do whatever else needs to be done. Then when we are ready to put it back on the lift in the spring we just drop it in and fire it up. Obviously we put the hull drain plugs back in and I will idle the boat on the trailer for a few minutes with the engine hatch up to make sure there are no leaks but it is pretty easy. If you are up north and they actually put antifreeze in the system then there might be a different process that is why I say best bet is to just reach out to your dealer.
