Originally Posted by
timmerz
I'll take pics tomorrow. I installed the thru hulls on the right (starboard) side in almost exactly the same location. pretty easy install. drilled 2 holes from the battery compartment into center hold, then into helm to run the battery harnesses. the wakemakers setup was fantastic. The only hitch I had was tightening the bronze thru hull, spun a little tightening down.
I used the existing drain tubing as overflow with check valves, had to extend to the top of the bags. I used the extra 3/4 tubing and fittings from the fill lines. Kept with the existing 3/4 lines for the center as well. didn't think it was worth pulling floor up.
