thanks guys for all the help. I ordered the new part and will put it all back together, refill the coolant and keep an eye on things. The coolant is propylene glycol and needs to be 50/50 mix with water right? Where is the best place to buy it?
I got it at Oreillys. Only place near me that actually carried it without purchasing thru dealer
Also Prestone Low Tox is readily available https://uploads.tapatalk-cdn.com/202...98e7f5d975.jpg
Where is the pump located? Is it easy to see for regular inspections?
Sent from my SM-S911U using Tapatalk
Interesting that the pump is designed for Rv fresh water pumping. The water temperature going through would be at ambient whereas this application would be at the coolant temperature. Could that be an issue with the case cracking?
