OUTBACK Prop question
Has anyone gone throught the trial and error as far as what props work well with an Outback with the 325hp. I have two pre teen kids about 70 lbs each and sometimes an adult at 180 lbs. We do alot of tubing, skiing, and knee boarding. I am waiting with the wake boards for a year or so.
Most boat companies do a lot of R&D to put the "best" prop on your boat for it's designed use. I am pretty happy with the stock prop as far as it's performance for an Outback. Is there something that you are unhappy with in your current prop?
I gotta go with Maxpower on this one. The stock prop does a great job on the Outback
Stock prop works well. I'm 6'5 215lbs coming out double boots with no problems. Toys are just as good.
I previously had 04 Outback with 310hp carb.. i dinged my prop and replaced the factory 13x13 3 blade with an OJ XMP 13x11 (which I am told is the same as the factory upgrade wake prop). Got better holeshot, but lost top end and ran at higher RPM for most towing. If you run ballast, you'll enjoy the added holeshot. based on your description of your riding styles, I'd stay with what you got until you start adding ballast....
I would actuallylike more on the top end for speed. I don't need all the grunt out of the hole for obvious reasons.
Gotta agree, sounds like the stock prop is the way to go for you. I also have a 325hp Outback, mostly ski, but does the trick for everything I have ever pulled.
Why do you want more top-end speed? Just curious.
Cheers
Why??
I'm just throwing some #'s out but after about 85% throttle the only thing that increases is my fuel consumption and RPM's. Seem's to me if it could grab more water I would at least get something from it. Also for fun.
I have a boomerang with a 310 carb. My original prop is a 13x 13. it had a slight ding in it that caused a cavitation burn on the backside of the prop. I changed it out to a 13D X14P and seems to be doing well with boarding, tubing, and skiiing.
I dinged my stock prop and put a rebuilt one on, but I didn't like it. I then bought an 13x13 4 blade. Great holeshot and good top end, about 45 on the GPS. Only problem is that there is a slight rooster tail now which affects skiing under 36 and tubing. So to get to my point, I wouldn't go this direction, and I still think my factory prop was the best. But you should feel free to get ahold of the boys at OJ or Acme, they will hook you up, but remember this will be about a $400 - $500 experiment
