The wakeboard wake is clean on both sides even at slow speeds. Haven’t rode it yet to comment on how it actually performs.
Happy Sunday. This comment is 100% correct. There is no bow ballast option in the Max for 2018. The three giant 1000 lb. bags do well. I am working on custom WakeMAKERS under seat bags that will connect to the factory rear bags. You will need to cut a couple holes in the divider between the rear locker and under seat area. I will find out the best location and make a little cut template for it. I am also going to see if a different size bag in the rear lockers is worth it.
This is one boat that you should order with the 6 ballast pumps due to its capacity and autowake. I am very excited to get the Max dialed. It is an awesome boat that in my opinion competes with those twice the price. That is still hard for me to wrap my wind around. HAHA. PM me if any of you guys take delivery of a new Max soon. I would love to get some bags in the boat for testing. Have a great day.
PM sent. My Max is already in operation. Gotta love the 80 degree SoCal winters.https://uploads.tapatalk-cdn.com/201...1256560dc2.jpg
So three dead bodies in each locker :o
That’s what I’m thinking, lots of bodies.
Should be interesting to see what WakeMAKERS come up with.
Hey guys. I would recommend spending the majority of the time getting the middle bags correct. You could probably add a few hundred pounds to the rear bags, but if you make the rear bags any bigger, then you will not be able to use the current drop in trays that go over the factory rear bags. Granted, you might not want to use the rear drop in trays, but after using the boat quite a bit, I HIGHLY recommend the drop in trays. It is hard to visualize just how deep those rear storage compartments are. IF you actually put anything into those compartments like a jacket or something, and then drain the ballast, you physically have to get in the rear compartment to get it. You can NOT lean over and actually reach the bottom and this is where those drop in trays really come in handy. The trays are deep enough to hold all the life jackets, ropes, buoys you would need and you can still access them when the ballast is full or empty. Again, I have used other boats with "subfloor" ballast, but even in those, getting items out of the rear storage is NOT easy, especially if you don't have good dividers in them.
One thing you will need in comparison to the current factory rear bags is an outlet (preferably) 2 on the front of the rear bag to then piggy back into preferably 2 inputs on the middle bag. You can get away with just 1 fitting between the bags, but if you have the 6 pumps, the 2 outlets in the back bag will drain the rear bag before the middle bag can fully drain into the rear bag. As an fyi, I am hoping we change this mid year or in 2019, but just giving you a heads up IF you decided to customize your ballast. Again, with 4500lbs of ballast and 4 or 5 passengers in the boat, I think you will be blown away with the performance.
So are you saying that if you want to piggyback some mid-under seat ballast into the rear bags, that it'd be best to get new custom rear bags with more ports so that the mid bags have the ability to flow into the rear bags? Because the stock rear bags aren't gonna have those extra ports for piggybacking currently?
