Auxiliary switches
I have a 2008 lsv, I have a dual battery setup and it appears I dont have power to my auxiliary switches. The boat starts and runs fine but the wake plate and all auxiliary switches appear not to have power. The main fuse appears to be fine. Any suggestions?
Check all the breakers under the dash
The power supply for these run in series. The first switch has to have power or none will. Should be a pretty easy fix if you chase the single power wire. I believe it comes direct from the ignition switch.
