Originally Posted by
smitty75
On my soulcraft’s, I’ve had to replace the traction pads just about every season. But they get a lot of use. I honestly think it’s the sun exposure that causes the most damage. I use a heat gun (very low heat) and pull the old pad, then throw on a new set. Just don’t overheat the board if you try this. I also have a smooth plastic scraper i use with goo gone if it won’t come up.
I didn’t think to try more adhesive since the pad is actually separating from the adhesive layer, rather than the adhesive pulling from the board. Let us know how this works after giving it a try. Regardless the traction areas are usually pretty beat up so I just swap them out.
