Anyone use non-trailer tires on their boat trailer??
Let me start with the idea that I know trailer tires are ideal. I'm curious if anyone runs or has experience running non-trailer tires on their boat trailers?
I have access to a set of rims that I really like to replace the steel ones that came on the trailer originally. The ones I have access to are 1" larger aluminum. 15" OEM to 16". The issue is that the fenders were obviously designed to accommodate the 15" rims & I only have 30" of clearance. So I need a tire that is 28" in total diameter to make that work. And I don't really want to replace the fenders. It doesn't appear as though a 16" tire of 28" or less exists in a trailer version. I'm assuming because they would be considered lower profile. I know I've seen a lot of newer boats with huge rims & lower profile tires. From what I'm seeing, I'm guessing that means they're using some sort of passenger tire rather than STs. Trying to decide if it's worth the risk or not.
Yes, most current Boatmate trailers with the 18” option uses a p metric automotive tire.
The critical thing is that the tire and size you pick has a high enough load rating for the total weight of your boat,trailer and gear.
For example, a dual axle Boatmate trailer for a Supra SA with 18’s runs a 255/55/18 tire.
The load rating is 109 XL or 2271# max load at 50psi. That is 9084# max load for trailer/boat/gear.
A 28” tire in a 16 is looking like a 235/65/16 and the highest load rating would be 1929# each, is that high enough for your boat/trailer/gear?
Edit: You can get 235/65/16 is a load rating of 3195# each.
Side note, Boatmate uses trailer king rst tires, they have a higher load rating BUT are made in China, so take that into consideration.
