thanks. I now see what you guys are saying... maybe i should just run my own wires with their own fuse...
Eusst1. You have same boat and light. What did you do?
Any updates on these installs by chance? I was going to order the Loki, but sounds like it might not be worth the hassle... especially if the wiring isnt rated.
I know this has been covered somewhere, but those wires that are pre-ran, are they the black and yellow wires that are plugged into one another? That’s the only wires I see back there with pig tails. Didn’t want to unplug them and hook up my drain plug lights with out checking first. 2018 Mojo
Marine illumination blue. May have a black tracer, but the primary color is usually blue.
The wires are in the engine bay, against the stern wall on the starboard side (not by all of the junction boxes on the port side).
Take off the black plastic decorative "Moomba" thing for more clearance. You can also remove the starboard side engine/ballast divider panels, although it isn't necessary.
The wires are almost impossible to see without first pushing the bilge vent hose(s) out of the way. Even then, they are zip tied to a horizontal cable run (terminated ends stick out on the starboard side of the wire run), so you can just barely see the wire ends poking out. They are labeled as underwater lights (there are two pairs, btw), so you'll know you have the right ones (and are blue with grey stripe, if I remember correctly). Clipping the wire tie provides enough slack for connections.
Old thread I know but buying some stuff for winter projects. @spatty99 you mentioned 2 pairs. What is the other pair of wires for if not underwater lights or do they belong to a different acc switch?
