I’m fixing to change the oil and have a question about the cartridge style filter. Do I add oil to he canister like you would a spin on filter or just put it back together dry? Thanks
I wanna know did if while changing the vdrive and transmission oil did anyone else extract much less fluid than the manual states it holds?
I am going to do all of mine this weekend. Did you end up pulling a screen on the bottom of the vdrive or transmission? I had my first service done at dealer so this is my second. Ordered fluids and filters including the inline fuel filter. Also new impeller and impeller puller. Always fought with the needle nose pliers with my last boat. I’m over that. I will keep track of how much of each I am able to extract.
I was told by indmar that there is no screen to pull. I didn't look for one since that is what I was told, I just sucked the fluid out and put new fluid in and used the dipstick to know when it was full. Took a lot less fluid than the manual called for to show full by the dipstick.
