Glad it worked out for you, Note, as you add weight to the Goofy it will keep getting better to a point, once you start seeing that tall wave with a short pocket, have someone larger sit in the bow on the surf side.
As you get more and more people you can have someone sit on the port side but you might find you have to lower the bag weight to keep your weight clean.
Now you have a good base to work with on your wave. Its a balancing act with your weight in the boat as much as it is you on the board.
Also glad I could contribute to you getting her dialed in.
