Adding Amp and sub to 2021 Kaiyen
2021 Kaiyen is coming with base cabin audio (4 wetsounds cabin speakers off of the head unit) and two rev 8’s on the tower with amp from the factory.
Goal: Add a sub in an enclosed box below the helm or OB storage powered by an amp and power the 4 cabin speakers with an amp
Quality: I have a young family and am on a small lake and don’t need to be the loudest on the lake. I just want to add some balanced bass to the audio is all. Budget conscious, good value.
Questions
1. Do I run two separate amps (one for cabins one for sub) in addition to the tower amp? If so what do you recommend?
2. Do I run a single 5 channel amp for the cabins and a sub? If so what do you recommend?
3. Sub recommendations?
Thank you
PFA
https://uploads.tapatalk-cdn.com/202...1cf9e7b03f.jpg
Quote:
Originally Posted by
MLA
For a solid value setup, Id be all over Kicker KXMA900.5 (when it becomes available) marine amp and a KM10 or 12 woofer. These woofers are offered in a free-air and small enclosure versions. The woofer chnl of the amp will deliver up to 400W rms and the 4 full-range chnls will allow for better tuning v's the head unit and room to add a 3rd pair of in-boats.
Any thoughts on the wetsounds as-10 sub/amp/enclosure?
