https://www.boatpluglight.com/collec...-2-solid-brass
Anyone have any experience with this item? Looking for an easy way to add some underwater light to my boat.
Thoughts?
Thoughts?
I was eyeing this initially but after some further looking, I’m leaning towards the Electra instead.
Simple install, triple the output and comes in RGB.
Sorry no experience with either though.
Check it out... https://boatpluglight.myshopify.com/...-drain-fitting
Anyone know if there is wiring to the back of the boat to tie in the underwater lights when they are not factory installed.
In the new Moombas, yes.
Any idea where?
In the new Moomba’s (like my 2017 Craz) there is a wire with a crimp on it behind the plastic panel on the stern of the boat, inside the engine bay, behind the engine. You have to remover the black panel to see it. When you lift up the center cushion/engine cover, look at the hinge, then look under the hinge. That is the black panel,you need to remove, and the wire is up under the gunwale on the right side as you are looking back towards the stern of the boat.
Awesome thanks for the info, I will have a look and see if it is the same on my supra.
One of the unmarked accessory switches. I don’t remember which one off hand.
how is the lighting any pics of it installed?
