RE: 2015 Moomba
MH
Michal Haney <
[email protected]>
Reply|
Today, 9:09 AM
You
You replied on 11/21/2017 10:11 AM.
Your trailer has (2) 3500lbs Spring Axles and a GVWR of 7000lbs. Your boat weighs 3900lbs with no fuel or extra accessories and the trailer is 1250lbs. Base weight of the trailer and boat, empty, is 5150lbs. Dividing this evenly between the two axles would set them at 2575lbs a piece.
Adding an extra 1000lbs to the boat would set it at 6150lbs. Dividing this evenly between the two axles would set them at 3075lbs a piece.
The numbers above are only if the weight is evenly distributed between axles and with an empty boat. Many times weight is just added to the rear of the boat for bigger surfs.
Now, some drawbacks to adding weight to the boat are as follows:
1. Tongue weight will be affected and overall towing can be affected, even if the trailer is level. The trailer can walk behind the tow vehicle.
2. Adding weight can cause to overload the axles. When the trailer axles are overloaded then can bend as they have a camber built into the center section. Once the center section is bent, the entire axle will need to be replaced.
3. Overloading can cause bearings to fail, repeatedly. The overloading of the axle will put pressure on the center section causing the wheels and tires to sit at an angel.
4. Uneven Tire wear can and will occur. In the picture above, you can see the overloaded trailer tires will sit at an angel. The tires will wear on the inside severely and blow.
Attachment 26477
I don’t want to tell you what to do with your boat and trailer, however, we have seen issues with this in the past and strongly suggest against it. Our trailers are made only for the boat with a full tank, and whatever accessories (ie speakers, boom tower, surf tabs) may be added. We don’t calculate for additional weight to be added.
