This is exactly what we do as well. Its parked in our shop but no heater in there and I wouldn't want to take any chances. Winterizing is the hard part IMO, changing all the fluids is the sucky part.
A few questions - my first go at this
Looking at my 2017 Helix manual it seems there are just 3 blue plugs (side and bottom of heat exchanger and front of V drive) and you undo the two hoses that rest on the V drive and drain, right?
Some remove a bolt on manifolds, but I feel that is just if you don’t have the two hoses?
Do you really need to remove the impeller housing too?
I’ll run some antifreeze through the ballast pumps to be sure we are ok too.
You are truly over thinking this.
Download the manual on the Indmar site and go through the winterization section. Anti-freeze is not really needed and using the wrong kind can hurt seals and such in the system.
Remove rear bags and drain as much as possible. Store out of the boat.
Remove 3 blue plugs side and bottom of heat exchanger
Remove raw water impeller cover and remove impeller - leave open
Remove plug/cap from manifold crossover hose T. If no T, disconnect lines and leave apart to drain.
Remove drain plug from rear of V-drive or remove a hose (depends on the V-drive in your boat, see manual)
Remove 2 hull plugs center and rear to allow all water to drain.
All in it took me 35 minutes and I didn't have the manifold hose, I have 2 individual plugs. I also have to remove the anode drain in the heat exchanger because I do not have the updated version with the blue plug. The impeller tool is worth the $45, I bought one last year.
I also had maintenance to do and made a day of it, but that is your call. Oil extractor is your best friend and hooking a 1/4" air disconnect to the drain hose is the best hack I read on this site. Spark plugs are time consuming but not hard, just a bunch a stuff in the way. My air filter was super dirty but it is dry type K&N and easy to blow out. If you never changed them in 5 years, I would recommend changing the ballast impellers. Mine were hard and my fill times were slow on the center so this should improve things.
Take your time and do not drop anything. I put all plugs, screws, covers, etc. in a zip- loc bag and stored in the glovebox until spring.
