2014 Outback V ballast bag leak
The ballast bag in my ski locker slowly looses water, but the digital readout still shows the bag at 100%. I pulled the empty bag out and it appears to be in good shape with no visible tears or punctures. Any idea what would cause it to loose water? Do I have a bad valve or something somewhere? I'm pretty new to all of this.
Maybe check the fittings? And the 100% would never change because they just use timers to set the percentage, there is no actual water level reading.
As others said, check the fittings. I discovered a leak in one of my bags the other day as the floor was wet under the bag. Turns out the o-ring on the bag fitting got pinched at some point and was leaking by.
