Originally Posted by
ninedriver
A few things to consider when pulling the dreaded tube. First of all I hope you don't have it hooked to the the tower, way too much load and could damage things. Second of all, if you have it hooked to the ski pylon like most everyone, that's still elevated enough that when you make a sharp turn the drag from the tube will actually pull (roll) the boat over more thus exposing your prop to a greater chance of cavitation.
Also, as far as tube pulling technique. When you pull from the ski pylon, it's a lot more difficult to whip the tube around because when you turn, the boat is almost pivoting around the pylon (just forward of it) and you lose that tail whipping movement that most of us are used to on conventional ski boats. If you have a transom attach point, you may try hooking a tube there, but your riders will have to deal with more spray generated from rope splash.
