I have come up with the dimensions and volume according to the manual for a km12. Did your port include the 1/2” front panel or did the port come thru it? If there’s any sub people in here could you look over my specs? There are 2 figures since I’m undecided on the depth. Thanks
https://uploads.tapatalk-cdn.com/202...ce8986941e.jpg
I did not add the port to the drawing yet because I’m. It sure if it needs to come thru the front or be flush below and use the front panel as 3/4” of its 16”.
My port came through the face of the panel. You can see the black ring of it if you look close to one of the pictures I posted. I took the outside dimensions of the port to figure the volume of the port assembly. Then I subtracted that from the inside volume of the box to get the total volume close to the specs.
Here are my amp settings. Again I am no expert, but is sounds pretty damn good to me.
https://uploads.tapatalk-cdn.com/202...bb59f27b58.jpghttps://uploads.tapatalk-cdn.com/202...835c4d9242.jpg
I messed up on my box measurements. I am using a km12. It has a minimum vented of 1.75 ft3. I made my box 1.80ft3 but forgot to add in the port. I really need to build a 2.20ft3. That way once the port is added I’m at 1.75.
Scratch the amp settings above. Mike gave me a few tips and these amp settings are much better. It sounded good before, but now it is just ridiculous. [emoji12] Thanks Mike!
https://uploads.tapatalk-cdn.com/202...595ffc9e73.jpghttps://uploads.tapatalk-cdn.com/202...658cff555c.jpg
Awesome! Glad you found some improvements.
