Mondo stereo make over, have some questions (battery and wiring)
I am adding (2) 6v batteries for my (new) stereo bank. Along with that, I am adding an Exile Javelin for my cabins and new sub and keeping one of my 800.4's for the towers. So I am basically re-wiring everything with a new dual switch (no ACR). I thought I had it all figured out then realized I am not sure. My question is ....do I need to have an inline fuse between the com post of the battery switch and the distribution block I am putting in (I was planning on the block being fused as well). I will be running new 1/0 cables with a single 1/0 in 4ga out distribution block. At first I was planning on just using the fused block with mANL fuses to match the fuses of the amps but I keep seeing others using an inline fuse on the 1/0 line from the battery switch to the block. Do i need both fused, or just one or the other. Other than that, I think I have it all figured out. Also, the Javelin has (3) 40a fuses and the 800.4 has (2) 30's, so I would be a total of one 180a fuse on the inline and a 120 and 60 on the distribution block?
With that said, anyone looking to switch to 6v golf cart batteries, Rural King (if you have one near you) sells their branded Exide battery for $79. It's not got quite the advertised spec of the Interstates, but it's damn close and Exide makes a great battery. At that price you can buy two for about $30 more than one Interstate or USbattery.
Thanks for the help. I thought I was going to be able to do this just on research and reading, but not so much.
