So Supra went live with the 2023 stuff any predictions on how long until we see the Moomba 2023 update?
It's pretty crazy the amount of reinforcing you need to do on the engine divider panels to make them stick. I don't mind doing the work to upgrade the ballast because it's pretty easy work and gives a ton of bang for the buck but the engine divider panels just seem like an engineering fail.
Seems like a decent market for an aftermarket moomba panel reinforcement kit.
$$$$$$, send me $5 per set for the idea.
Between thrusters and reinforcement kits………nevermind.
I will say the Supra’s still have stout dividers and the ballast is all subfloor. They should swap Supra panels with moomba panels, Supras don’t need them, moombas do.
My main frustrations (2021 Mojo):
1. Gatorstep (brown) peeling off in several places after 1 year
2. Bimni coverage w/upgraded tower is not enough, same with seat height issues
3. "Altitude/wake" prop option of (15.5x15) is completely out of touch with what is needed
4. Stitching around step pad (from transom to cabin) is not robust enough or needs a redesign
5. Sound dampening needs to be better
6. Rudder position indicator
Now there is a good idea. The hdpe, or possibly mdpe they are using in the Moomba is just the wrong choice. The design shape is not ideal in my opinion, but with better material it would be acceptable. What is the material in the Supra?
What do you think should be the "Altitude/Wake" prop? Lower pitch?
I swapped to a Acme 15.5 x 13.0. Lost a lot of top end speed, but it does surf better. Thinking of maybe sending back for 15.5 x 14.5. FWIW I emailed OJ props and the 15.5 x 15.0 is what they suggested for surf specific.
I have the 15.5x15 on a Makai with a 1.76 trans and a 400 motor. WM ballast upgrade, full gas and crew of 10 or 12 (I have had 18 before too) I am pushing 12,000 lbs plus or minus a couple hundred depending on what grown adults are there. I have always been able to reach surf speed. I am just a few hundred feet above sea level though.
