Wiring a pair of Rev10 Speakers to Syn4
Does anybody have the preferred method for wiring a pair of rev10s to a Syn4 amp?
I have it installed right now with one bridged on the front and the other bridged on the rear. I notice that I had to adjust both the front and rear gains together.
Settings on the amp are currently:
Front and rear freq about 90hz and set to high
Source select in 2 channel
Front and rear both set to “bridged”
Only using 1 set of rcas on the front ports
Blasted some tunes and turned gain up on both front and rear until I could hear distortion and then backed them off a little bit. I didn’t play with any bass boost.
Now that they work so well, is a line converter to rca the best way to control them independent from the rest of my speakers (2015 Moomba Mojo)?
