Sorry for question, but our new boat will be coming with all of the Ballast / surf upgrades. With that said, can you use this in a "Manual" way? example it you want a different pitch or roll access, or "fine tune" something.
I can only assume the operation of the 2019 is similar to the 2018 with the exception of the screen change. That being said, yes you can use the system manually without Autowake. There is very long thread on here regarding the proper use of Autowake. Read through all of Goose’s posts and you will be an expert. I was able to get a great wake the first trip out after reading the posts. It took about 5 additional times to completely fine tune it to my specific liking on pitch / roll / speed / etc. just be patient and you will be happy with the results.
Get the sensors.
Posted this question elsewhere on the forum before I say this thread. Any ideas ?
We still have snow on the ground up here but I got excited about the new flow sensors for my 2018 Max so I popped into the dealer yesterday to enquire about upgrading. They said that they are working with SC to figure out what will be required but warned me that the upgrade will be expensive for the 2018 Max due to them having to "split the hull" in order to get the necessary access to install the components. That much work would make the upgrade not work doing. Has anybody else been told that's it's more complicated that installing the sensors and upgrading the software?
John
2018 Moomba Max
Calgary, Alberta
I called a dealer about upgrading my 2017 Mojo. GOOSE stated in this thread that is possible. But the dealer said they called Moomba directly and were told it is NOT possible for a 2017.
I tend to believe GOOSE, and thus hate that dealers know less than their customers.
It is a actually quite frustrating.
GOOSE, any suggestions on how best to explain to the dealer that this upgrade is possible and was Moomba's intent to make it so?
Sent from my SM-N950U using Tapatalk
Pretty sure I read its backwards compatible with only 18 autowake Moomba
