2003 outback, a few issues
Skiied in the morning for about an hour. Then after shutting the motor down (indmar caburated 310hp) it wuld turn over for a second o two and stop. It did this repeatedly. The temp was at 180 degrees (normal) when this happened.
I got towed back and later that day it started with some hesitation at the same point where it died previously but ran well once it started. I checked the starter and it is ok. Is it an ignition issue? Is my battery causing this even though it can start the boat repeatedly? Fuel line/filter/pump? I did not think this because it runs nornally once started even reving it. Plug wires, cap rotor?
Any advice?
Other stuff, what is the best platform pad? What is the best way to remove the old one?
When I fill my balast it fills the boat with water plus it did not drain previuosly.
What is the best impeller? ideally one with more longevity than 1yr.
My gelcoat has cracks around the base of the swim platform and a few other places. What is my best course of action?
Love the boat but want to get the issues fixed.
