You said it starts after messing with the throttle? Sounds like a safety switch to keep it from starting in gear to me.
Since it’s not too hot out yet which can give some vapor lock/fuel pump issues, I’d say go ahead and replace the ignition switch (keyed switch in the dash)….
Got out Friday. Boat started every time. I did hear what was a pump or tabs run when key first came on. Boat was sitting on lift in the water. Not sure I would be able to hear the tabs under water? Plan on doing more troubleshooting this weekend [emoji3]
