They are the factory bags. As Stazi said, Fly High Fat Sacs. According to WakeMakers rep, they will fit in the Mondo.
i have FatSac branded bags now. They require a 3/4" setup. I know wakemakers own brand requires 1" all the way thru.
I think the big question is will you have the G6 Ballast system with 2 inputs for the connectors.
Some of the earlier 2019s didn't have the release valves for pressure either....I would just compare with pictures!
I do not have the G6.. i have G3 i believe. Takes about 4-5 or so to fill my 750's
If you look at the bottom of your rear bags and see 2 x fill\drain lines + a vent line then you have G6...or if you pop open the 2 rear carpeted panels and see 6 x pumps hiding...then you have G6...if you only have 3 x ballasts...then you have G3 :)
