Polish & Wax Fiberglass Finish...resulted in dull finish
Working with my 1998 Mobius that is white and metal flake blue. The finish is mostly glossy but the white has water spots and some lite stain or dirt. A search around the web showed Collinite as a good product to use to polish and then wax the boat.
So I tested two small 1x1 areas. The first one I applied the Collinite 920 Fiberglass Boat Cleaner with a foam pad on power rotary being sure to be on the lowest RPM (750-1000) and moving around so as not to heat up. I then wiped off the residue and applied the 925 Collinite wax and buffed with a wool bonnet to finish.
On the second area, I applied the Collinite 920 by hand, removed by hand, and applied/removed the 925 wax by hand.
In both cases, the surface is very smooth and very white but the gloss is gone. Its somewhat shiny but no where near the glossiness before I started. When you shine a light on the surface the untreated surface you can actually see the shape of the light bulb reflecting back at you. Over the polished area, you just see the reflection of the light, the surface is not mirror like if that makes sense.
Any tip here? Do I need to buff more with the wax and wool bonnet? Did the Collinite 920 basically eat my gloss fiberglass finish?
Mark.
