I have a 2006 Mobius LSV and my stock ballast pump(Rule 207F) finally died. I would like to upgrade to a little faster flow. Can anyone help me with a pump that would work? I only run the bag in the floor, no rear bags. Thanks!
quick search says that the 207f is a 1200 gph pump. To make it worth the cost, id look into the shurflo piranha 2000 gph pump. However, you will need to contend with the piranha's 1" threaded MST inlet adapting to where the rule 1200 with its .75" MPT inlet was. Johnson has a 1600 GPH pump that uses a 1" FPT inlet which might be easier to adapt. But, its a big heavy pump as it has a bronze base.
I'd go to dual Tsunami 1200's.
