Mojo Pro - Added Surf Pipe
I know some of you added the FAE surf pipe, I decided to go OEM and thought I’d share.
I read everywhere that installing was a nightmare. A local guy here did one on a Max through the dealer, he said he got lucky as they charged him 4 hours, and the dealer told him after that it took 10, but they ate the cost and honored what he was quoted.
Well, mine was pretty much plug and play and took less than 45 minutes. Maybe the Mojo Pro, or maybe I got lucky, but there’s 2 hose clamps from the inside, 4 screws on the flange through the transom, and resealing is all it took.
Here are some pics. Hardest prt and most time consuming was breaking the seal on the existing exhaust flanger, and when I dropped my hose clamp bit under the motor. Removed 4 screws from exhaust output, broke seal, removed flange, cleaned/sanded removed remaining sealant, resealed and mounted the pipe, tightened hose clamps inside. Plenty of room back there on a Mojo, didnt even scratch a knuckle.
https://uploads.tapatalk-cdn.com/201...fbd6be3c61.jpg
https://uploads.tapatalk-cdn.com/201...ad4b8646e6.jpg
https://uploads.tapatalk-cdn.com/201...8bba4c16f0.jpg
https://uploads.tapatalk-cdn.com/201...c580a13f60.jpg
Quote:
Originally Posted by
2018MojoPro
First outing with the new pipe, and yes, there’s a pretty big difference. Especially at lower speeds it seems, near silent. On acceleration you just hear the gear and engine wind up, no growling exhaust coming from that air pocket under the deck.
Good purchase!
You will find you don’t need your audio anywhere near as loud unless you just are that loud music guy on the lake.
Surf pipes should be required
Links to youtube cracked pipe videos? I din a search and didnt find any. Mine is through bolted as well
