Moomba Flow Surf Available for 2006 and Newer LSVs
The thread I linked above was super easy. I added the IBS, and replaced my 2 rear bags with the 1100s. The IBS is filled from a line running from the top vent on my center bag. I use the bosworth valve which let's me choose if I want to fill the IBS or not. I also added the check valves which help get all 4 of my bags flat.
1 Attachment(s)
I was trying to pull up my order from Wakemakers, but it won't come up.
If you aren't doing the Bosworth, I'm not sure you need a Y. Mine is used for the overflow of either the IBS or the center bag depending on which way I have the valve turned.
I cut the hose coming from the thru-hulls at about 8". I installed the check valves there. You can see it here:
Attachment 19762
From memory I ordered:
Check Valves x 3 @ 3/4" (my vent line sizes)
Bosworth x 1
Y barb x 1 @ 3/4"
Stainless Steel Crimp Band Clamps x 10 @ 3/4", 6 @ 1"
1" to 3/4" hose barb
The necessary quick release connects (M/F)
1" hose and maybe some 3/4" hose, but not sure on that. I tried to reuse the original vent line from my center bag. I might have moved this to the IBS.
I ordered the crimp clamp tool on amazon, at the time they had a better price. That tool is very handy for clipping of cotter pins too.
That list is all from memory, so I might have missed a few things.
Ron & I pretty much did the same thing, I just included the valve.
Re: Moomba Flow Surf Available for 2006 and Newer LSVs
Quote:
Originally Posted by
1danlay
Install video coming soon on activeh2o.com
Awsome!!!!
