Mike I need a picture of that cable setup next time you are hooking the boat up. I can't visualize it this morning.
not to call ya out MM cause you my boy but the manual says not to hook the emergency break away cable to the safety cable. says the emergency cable should be hooked up separate and Independant as to function properly in the event of actuvation
sent from my home phone
Na Bro you can call me out lol
It is hooked up seperatly to the hitch, it just loops back and connects to the cable.
Basically try to picture this mang.
Saftey Chain or cable hooks right on your hitch, and you should be crossing the left to the right so it forms an X under the tongue incase the hitch ball breaks this will help catch the tongue.
Now the saftey chain i also run it through the hitch eye and then back to the safety chain <cable> and it connects to the cable.
This way if the safety chain <cable> breaks due to the boat unhooking, it will force the brake cable to be pulled, also this way makes it so when i disconnect the safety chain <cable> i also have to unhook the Brake cable at the same time. This makes it physically impossible to forget to unhook one of them.
