2012 Moomba Mojo Wont Turn Over
Hi, everyone!
I've got a 2012 Moomba Mojo 2.5 in the shop that will not turn over. Turn the key and nothing. All other dash components operate, though. Without being able to turn the engine we cannot get a proper scan of the engine and therefore cannot collect any data or faults.
It's like there's a neutral safety switch problem, but after playing with the gear shift lever hundreds of times still nothing. Anyone know where the neutral safety switch is located on these? Can't seem to locate it on the transmission.
The battery connections are good. The red indicator light by the gear shift lever is on, though. It says "Do not run V-Drive over 1200 RPM / Low Oil Pressure / Check Oil Level". But the engine should still turn over with this light on, right?
We have 5 quarts of oil in it at the moment, and while that is a little on the low side, I think it should be at the level of the sensor in the oil pan. Could that be the problem?
New starter on this boat, but we turned it with a jumper wire just to make sure it operated properly. Checked the 20A fuse for the starter on the fuse panel on the engine and it's still good. We verified power from the batteries all the way through the yellow starter wire to just short of the computer. But after the computer, nothing.
We checked the main breaker on the fuse panel, got power through there. We pulled the starter relay and will play around with that.
I keep going back to the neutral safety switch, but have no idea where it is located.
Everyone has been great with the ideas in this forum in the past, hope you can come to our rescue. Your ideas are greatly appreciated.
Thanks!
