My registration #s came in from Domednumbers.com , yellow and Ultra Black metallic flake...
https://uploads.tapatalk-cdn.com/201...32b42ee1b7.jpghttps://uploads.tapatalk-cdn.com/201...d3019e08ac.jpg
Sent from my SAMSUNG-SM-G935A using Tapatalk
[QUOTE=RC_Hinojosa;308512]My registration #s came in from Domednumbers.com , yellow and Ultra Black metallic flake...
Those look fantastic!
Amazon upgrade #2...
Picked up another 4 ohm KM10 and a rhino-lined dual ported enclosure.
Two 4 ohm KM10s wired in parallel, presenting a 2 ohm load to the factory KM800.5....this is what factory should come with...this thing bumps!https://uploads.tapatalk-cdn.com/201...d39a20ca56.jpg
Yessir, here you go: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks but it’s not going to work out. I removed the factory kicker 10” and it is 2 ohm. Was hoping it was 4 ohm so I could just add another. I have the kicker 800.5 amp so I guess I’ll just have to start over. Thanks again.
That is odd because I could swear the factory KM10 was 4 ohm, maybe mine was a fluke? You'd probably have a hard time off-loading the single 10" but you could snag (2) 4 ohm KM10s off Crutchfield for about $300 - https://www.crutchfield.com/p_206KMW....html?tp=61750
Good luck and sorry for your trouble.
No problem. Thanks for sending me the link. Since I have to start over I may just go wetsounds. Here’s a pic of the back of the sub. I’m assuming because on the kicker 800.5 you get 200@4 ohm and 400@2 ohm on the sub channel.https://uploads.tapatalk-cdn.com/201...8ff6c36231.jpg
