just make sure the IBS is pulled forward before you start to fill it to prevent the cup holders from popping. I think I also used to put part of a pool noodle there to keep the IBS forward.
I just pulled the cupholders. I know someone on the forum actually made a plate to cover the holes. I don't think he had the center bow cushion.
So how many of you guys with the 1100s reinforce your rear lockers?
What kind of reinforcement does it need? I've got my 1100 coming tomorrow.
I never really fill the starboard to 1/2 full but the door bows a little on the port side. I think again the higher deck on the 13 up LSV reduces the pressure on the dividers. I didnt remove the carpet covered front spacer at the top on both sides of my lockers gives you a little more room. You just have to watch the edges of the top deck. I ran a sanding drum along the edges to get rid of the sharp edge. The 1/2 dividers bowed with the factory ballast. I've installed the flow havent tested it yet. I hope to not have to run quite as much weight.
Does anyone have the flow surf on the lSV's? just ordered a set after seeing how well they worked on the mondo.
I don't own a LSV, but have surfed a 2015 with the FLOW and it was a great enhancement, IMO. Let the boat ride more level, lengthened and cleaned up the wave. We weren't focused on the side-to-side switching, so really didn't pay any attention to that.
